Displays the OSPF redistribution configuration information.
The route policies treat permit and deny rules differently for inbound and outbound traffic.
For an in-policy (RIP, BGP) or an accept policy (OSPF) using a route-map, if a particular route is not explicitly denied in the accept policy or in-policy with the route-map, then the route is implicitly allowed.
For an out-policy (RIP, BGP) or a redistribute policy (RIP, OSPF, BGP) using a route-map, even if a particular route is not explicitly allowed in the redistribution policy or out-policy with the route-map, then the route is implicitly denied.
In order to permit or deny only explicit routes, configure a policy with additional sequences, where, the last sequence permits all routes that are not explicitly permitted or denied.
Switch:1#show ip ospf redistribute ================================================================================ OSPF Redistribute List - GlobalRouter ================================================================================ SRC-VRF SRC MET MTYPE SUBNET ENABLE RPOLICY AUTO-FILTER -------------------------------------------------------------------------------- GlobalRouter STAT 0 type2 allow TRUE
Variable definitions
The following table defines parameters for the show ip ospf redistribute command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
